I am trying to measure the current flow of a Raspberry Pi Pico W running simple code that blinks the onboard LED saved as 'main.py'. I have verified this code runs when connected to a) my laptop and b) an external breadboard power supply.
When I connected an ammeter (GND on Pico connected to - on PSU, red ammeter probe connected to + on PSU, black ammeter probe connected to VSYS), the only thing I am reading is 0.51 mA when the PSU turns on. I am using a breadboard power supply supplying 3.3V with a 12V DC power supply plugged into the breadboard PSU.
The Pico does not execute main.py. Is there something I am missing? The range on my ammeter has been set to 20 mA, and then 200 mA when that didn't work, to no avail. Thank you!
main.py:
import machine
import time
led = machine.Pin('LED', machine.Pin.OUT)
while True:
led.on()
time.sleep(1)
led.off()
time.sleep(1)
