Given this circuit I’m asked to determine the transfer function from \$V_i\$ to \$V_o\$, but there are no answers given and my result disagrees with my earlier DC analysis.
I think think the first “stage” is just a voltage follower. By superposition, it’s easy to show that \$V_o’ = V_i\$ (though I'm unsure whether I'm allowed to split \$V_i\$ like that):
For the second stage
Since \$A_2\$ is ideal, there is no current through \$C_2 \parallel R_5\$ so \$0V\$ drop across it, and the inverting port follows the non-inverting one, thus there is \$-V_i\$ across \$R_3\$, and by Ohm's law \$i = -\frac{V_i}{R_3}\$ running through it.
After which I did KVL (red arrows): $$ V_o + i(R_4 \parallel C_3) + V_i = 0\\ V_o -\frac{V_i}{R_3}(R_4 \parallel C_3) + V_i = 0\\ V_o + V_i[1 - \frac{1}{R_3}(R_4 \parallel C_3)] = 0\\ V_o = - V_i[1 - \frac{1}{R_3}(R_4 \parallel C_3)]\\ \frac{V_o}{V_i} = H(s) = \frac{1}{R_3}(R_4 \parallel C_3) - 1\\ H(s) = \frac{1}{R_3} \frac{\frac{R_4}{sC_3}}{R_4 + \frac{1}{sC_3}} - 1 = \frac{1}{R_3} \frac{R_4}{sR_4C_3 + 1} - 1\\ H(s) = \frac{R_4 - sR_3R_4C_3 - R_3}{sR_3R_4C_3 + R_3}\\ H(0) = \frac{R_4 - R_3}{R_3}\\ $$
However, I've found earlier through DC analysis (\$R_1, R_2, (C_2 \parallel R_5)\$ are short, \$C_3, C_1\$ are open) that the DC-gain should be \$1 + \frac{R_4}{R_3}\$.
I'm not even sure where to look to find my mistake.
- V_i
. I'm not sure what the correct procedure here is, should I answer it myself and pick that answer? \$\endgroup\$
