I'm trying to wire up this AC to DC converter and have never seen the connections that this thing came with.
The converter is an Emerson R48-3200.
The label shows AC input 200-250 Vac 18 A 50/60 Hz.
DC output is 48 V 3200 W.
It's the AC input side that is confusing to me and how to wire it up in a 120 V world here in the U.S.
There are 3 pins on the Emerson AC connector labeled as Pin1=Gnd Pin2= N Pin3= L.
The cord it came with has an SCED TP950P on one end that plugs into the back of the unit and on the other end of the power cord it has an connector labeled C3-10 10 A 250 V. The C3-10 seems to be a standard Chinese Type I plug but I can't find any adapter cables.
I have previously wired up a 240 V USA Nema 6-50R but it doesn't use a neutral and has only two Live connectors and a ground. I'm hoping to find the most economical way to wire this up. I could make an adapter but would need to find a source for these plugs, or I could cut the cord it came with in half- and make the connection from there, or ?
I want it safe but I'm the only one going to be using it.
So how do I wire the 110 V wires from my panel to get 240 V and do I need a Neutral plus a ground?
Don't want to guess but do I join two hot wires together to L connection?
