AVR ATMEGA16 Minimum System Board ATmega32 Development Board + USB ISP USBasp Programmer ISP ATTiny 51 Board and PLCC32 to DIP32 EZ Programmer Adapter Socket
Hi all,
Very very new to all this...
I bought the above with the intentions on flashing a bios file to a PL-CC 32 socket chip. I have spent a good amount of time getting nowhere unfortunately. With all the guides I found and advice I have seen on other peoples forum posts I havent progresed very far.
So far I have only managed to flash the latest firmware to the USBasp - after that I can't get any programs to show/connect/recognise that they are successfully connected to the USBasp.
I am obviously missing something or doing something wrong but I just can't work out what it is.
Any help would be greatly appreciated. Been at this a while and tried a lot of things so I have probably missed somethings I have tried.
I am just looking for information/advice on what to do and how to connect etc... after flashing firmware to the USBasp.
I am using Windows 10 64 I closed off JP1 in order to flash the new firmware on the USBasp I have flashed the latest firmware to the USBasp via another USBasp I have tried using elevated CMD with avrdude installed on my system eXtreme Burner - AVR AVRDUDESS Arduino IDE
I get errors such as detecting the MCU... Warning: Unable to detect MCU
and
avrdude -c usbasp -p m8 -P usb
avrdude.exe: error: usbasp_transmit: No error avrdude.exe: error: program enable: target doesn't answer. 0 avrdude.exe: initialization failed, rc=-1 Double check connections and try again, or use -F to override this check.
