Related to my previous questions, I would like to know what the approach for determining the loop gain and transfer function of the circuit presented below is:
The circuit is highly simplified. The VCCS would in reality be a differential amplifier loaded by a current mirror and would have big input and output impedances. VG1 is meant to represent the unregulated input voltage of the regulator with a DC level and a significant AC ripple. V1 would also be a Zener voltage reference.
This representation is closer to the reality of the circuit:
For DC conditions I calculated the closed loop gain to be:
$$V_{o}=\frac{g_{m}(\beta + 1)(R_{1}+R_{2})}{1+g_{m}(\beta + 1) R_{2}}\cdot V_{ref}$$
Simplifying for
$$g_{m}(\beta + 1) R_{2}\gg 1$$
gives the usual
$$V_{out}=\left(1+\frac{R_{1}}{R_{2}}\right)\cdot V_{ref}$$
For the low frequency closed loop gain / open loop gain the result is the same. I obtained it by breaking the loop, passivizing all DC sources and replacing the transistor with the small signal equivalent model.
I am almost certain I made some mistakes in my derivations.
What is the correct approach?
