I'm designing a peak sinusoidal and impulse detector, based on the old design of a peak voltmeter designed by Haefely. I have the schematic, but I can't understand how this circuit works. The large number of elements in the feedback branch confuses me.
I would like help or an explanation on this circuit so I can understand how it works, mainly the feedback loop.
What I know this about the circuit is that it's purpose is to receive an impulse or sinusoidal waveform (attenuated by a previous stage) and obtain a DC or square pulse with amplitude proportional to the peak of input signal. The user can select if they want to see the positive or negative peak, using the relay on the A2 inputs. The output value is stored in C7.
Also, this circuit is a module inside an instrument that I know how to use and that works very well.
