You should measure the voltage across the capacitor rather than the capacitor relative to one side of the AC input. Also, it's bad practice to use automatically named nodes- always name them yourself. When you edit the schematic, the node numbers already present may change, which can cause you to plot the wrong voltage.
I would also suggest always using a real component model, rather than the default. The default may be very odd compared to a real discrete component- for example it could be for a tiny structure on an IC chip.
Above is a 1 second simulation of the circuit with the values you used and 1N4148 diodes. The time constant of 100 ohms and 11,000uF is 1.1 second so it will only reach a fraction of the final voltage in a second.
It's possible to leave the input voltage grounded and plot the difference between the two sides of the capacitor but I would suggest always grounding the most logical part of the circuit. Sometimes there are small anomalies from taking a difference.
In the case of the above circuit, if I wanted to plot the AC input, I could add a trace that plots V(Vx)-V(Vy) because I've named those nodes.
