I have a strain gauge (the BF350-3AA), and I will be connecting it to an HX711-based amplifier sensor.
From its low-quality datasheet, I've pulled out the following figures:
- Nominal Resistance: 350 ohms
- Sensitivity Coefficient (which I believe is also called the Gauge Coefficient): 2.1
- Sensitivity Coefficient Dispersion: <+/- 1%
- Transverse Effect Coefficient: 0.4%
- Strain Limit: 2%
Ultimately, the quantity that I want to measure is the number of micrometers of deflection over the length of the gauge. What is the minimum sensitivity (or precision) of deflection I can measure?
The gauge is being deployed inside a long flexure block of concrete, with its normal parallel to the axis of the press.
Bonus question: What formula do I use to calculate the deflection as a function of resistance (or resistance change)?
