I ask this question because I saw this in an Altium article:
In power systems, be careful how you use a capacitor to ground to ensure a consistent ground reference. Y-rated capacitors are best in this application, where you need to remove DC offsets between planes while still providing galvanic isolation and high-frequency EMI filtering.
As far as I know, capacitors block DC current and there is usually a non-zero DC voltage between a general ceramic capacitor. Y-caps are specially designed for safety purposes. It is placed between live and earth and is open when fails.
My questions are:
- Is practical Y-rated capacitor such a special capacitor that can even set two isolated ground references to the same DC voltage?
- I think 'remove DC offset' means having the same DC voltage. Do I understand 'remove DC offset' correctly?
(Here is a similar question but I cannot get a exact answer)
