I have a slight confusion regarding the saturation rating of transformers. I often find this value stated in Volt-Seconds, which is a unit for the saturation flux, i.e. the maximum flux that the core can hold. After all, the saturation flux density \$B_\text{sat}\$ and the cross section of the core \$A\$ are both independent of its windings. So their product \$\Phi_\text{sat}=B_\text{sat}\cdot A\$, which happens to have units of Volt-Seconds, has to be independent of the windings, too.
Therefore, I regarded the saturation Volt-Second rating to be a property of the transformer core.
But then I thought about what happens in a 2:1 transformer when I apply the same Vs to one or the other winding (with no load on the second winding):
- The inductance of the shorter winding is 1/4th of the inductance of the longer winding
- So the current through the shorter winding will rise 4x as fast
- So for the same Vs applied to each winding, the shorter winding will have developed twice as many Ampere-Turns
- So the shorter winding would have generated twice the flux for the same Vs (and would thus saturate at a lower Volt-Second rating)
Now I was confused, because the latter consideration would indicate that the Volt-Second saturation does in fact depend on the winding properties and is not a property of the core.
Where did I go wrong?
