I build a kind of audio amplifier (it's actually a mixer). The problem is that the output gives a high frequency pitch noisy sound as soon as I touch the front panel which is part of the chassis. It may be capacitive coupling?
This problem only occurs if a source device is connected which is not connected to mains earth ground in any way, for example a turntable. As soon as I connect a digital media player, which has a 3-prong mains cable, the high pitch sound is gone and the chassis does not seem to react to my body near the chassis anymore.
So how is grounding done right with a SMPS which only has floating output?
I tried to draw a simplified diagram:
What I tried already:
a) DC socket bond to chassis, SMPS ground and DC/DC converter ground connected
b) DC socket bond to chassis, SPMS ground and DC/DC converter ground isolated
c) DC socket isolated from chassis, SMPS ground and DC/DC converter ground isolated, DC/DC ground connected to chassis directly
d) DC socket isolated from chassis, SMPS ground and DC/DC converter ground isolated, DC/DC ground connected to chassis via RC network (100ohm, 100nF)
No option really gives a satisfying result. The high pitch is either always there or just when my body get's close to the chassis.
Happy to hear any suggestions!
(Additional information added after the first answer was written)
I analyzed the problem further and the noise I am getting does not seem to by only high frequency. In fact it is in the full audio range, with a big peak at 50 Hz (mains frequency)
Here are two distortion spectrums: earth grounded (top) and floating (bottom):
This is more than 15 dB more noise when floating. I am sure there has to be a way to solve this issue, as there are so many devices which are powered by regular floating desktop SMPS.
