I have a question regarding a Li-ion charger/protector module. The board I'm using a fairly standard Li-ion charger/protector module.
This module manages the charge using a TP4056 IC and has a built-in protection circuit using the DW01A IC.
Can I use this module safely to charge a 3.7 V Li-ion battery without internal protection? Most Li-ion batteries have an internal protection circuit (see image).
But when I use the TP4056 module as described and a battery with internal protection there is a double protection, and this seems to be causing problems. So I want to use a battery without this internal protection.
I'm assuming this is OK since the protection is present in the system only it is on the charge PCB and not on the battery. But I have done a lot of research and I'm still not a 100% sure so I was hoping someone could help here.
