I'd like to ask for help with calculating a gain of a PWM modulator using a triangle wave.
I know how to calculate a gain in case with a sawtooth carrier with turning-on at the start of cycle.
and
The DC gain equals:
and the AC gain is the same:
Where is an amplitude of the sawtooth wave and these realtions are valid for .
Next, I would like to calculate the gain for the same configuration but with triangle carrier instead of the sawtooth.
And here is my first question. Can I assume that the control signal is much slower than the carrier? I mean that I assume that the control signal has the same level at the beginning of the pulse and at the end? It can simplify a lot calculating the gain cuz it will be symetrical around the peak of carrier.
Could you help me with the calculations? I'm really confused how to start...
