Currently I am trying to self learn electronics. After the diode I moved to the transistor.
I understood the transistor as an “electronic” switch with no moving parts. When the base is connected, then the current can flow from the collector to the emitter. Otherwise it cannot.
Though, when I put 5v across the base, with no voltage across collector nor emitter, an LED, connected to the emitter through a resistor, lights up. Is this normal? Am I missing something on the functions of a transistor?
... that is not entirely correct \$\endgroup\$
