It seems that BMS's are for batteries in series...
If I have 3 x 1200mAh lipo cells to get pretty much a large 3600mAh 1S pack...
I believe I know that I can't just parallel wire single-cell BMS's together...
So I'm not sure, I was looking around and I could not find a BMS for parallel/1S configuration.
We pretty much just want a "giant" capacity battery pack but in smaller pieces.
I want a single charging input port... and then while in use if a cell is too low it turns off, others keep going, until they all fail or you charge before this scenario happens.
I know there are balancing chargers... we could just do that, but then our cells would be pulled without a protection board/hopefully they drain evenly.
I'm not sure if this is how RC planes do it, where there isn't a smart board on board (most batteries) but the charger deals with balancing.
Thanks for any ideas, looking for off the shelf/small approach.
