I would like to add some new components to the LTspice library. I have never done this before.
The online SPICE forum discusses 3rd party component steps. It says I have to download the SPICE model file from the manufacturer's website. I have tried to find the SPICE model file for the FDA69N25 MOSFET from Fairchild, but I can't seem to find the specific data clip.
There is the datasheet and other info regarding the packaging, but I just can't make heads or tails of the other export files. I don't know which should be the SPICE model file.
From what I have seen, if you know what you are doing it is quite easy to import the right component into LTspice, but I don't quite have enough experience with the simulator.
