I am using Altium CircuitMaker to design a PCB. I'm wondering if there's a way to make my PCB design without a schematic.
My idea is to simply make a PCB with just pads and populate it myself with the required components. For instance, right now I have set up some pads in the PCB for me to insert header pins into and solder and then I am planning to attach the PCB onto an Arduino Mega (as shown in the image.)
When I try to do some routing, it doesn't allow me to route pads. I did some research and I believe this is because I'm not using a schematic so I have no assigned nets. I'm guessing you cannot route without pre-assigning nets in your schematic. Is there a way around this or do I have to use actual components such as header connectors in the schematic, then assign nets and route?
  • \$\begingroup\$ Can't you use test points or similar schematic symbols? \$\endgroup\$
    – Lundin
    Commented Jan 23 at 12:57
  • \$\begingroup\$ There might be a way but you will be skipping a step so basically doing it wrong. If you do it like that, and the PCB has a problem, you have no schematic (or the blueprint, or the plan, whatever word fits) to show to anyone, to verify if the connections are right or wrong. The correct way to do it is of course to make a schematic and see that the logical connections are correct, and then move on to designing the physical connections in the form of PCB design, and the schematic connections will warn if the PCB connections are not properly made for example. \$\endgroup\$
    – Justme
    Commented Jan 23 at 13:06
  • \$\begingroup\$ @Lundin How do test points work? I'm quite new to this sorry. I'm just wondering if I can assign a net to the pads in the PCB diagram instead of using a schematic with components + nets? If not, I think I will do as you said by using similar schematic symbols. \$\endgroup\$ Commented Jan 23 at 13:08
  • \$\begingroup\$ @Justme That is true. If I decide to go about it that way which I have tried before, what would I do for example, when I need something like a single header pin? On Altium CircuitMaker, there aren't really any symbols for a single header pin. \$\endgroup\$ Commented Jan 23 at 13:11
  • \$\begingroup\$ @Vagabond4761 For what you need a single header pin? Put the correct connector there to begin with, there are likely footprints for mounting an Arduino, complete with pin numbers and names. \$\endgroup\$
    – Justme
    Commented Jan 23 at 13:13
As discussed in the comments, the correct way is to create the schematic for it.
If, for any reason, you want to do it in the PCB, you can do it by setting the net names. First, you need to create the net. From the Design option, select the following:
Design->Netlist->Edit Nets
Then select "Add". From the window, set the net name you want. I've used "Net1" for example. Press OK to create the net.
Add net
Add as many separate nets as you need.
Now, you have a net to assign to pads. Select the pad and open the properties window for it (or simply double-click on the pad to open the properties). In this window, there is a "Net Name" field. For example, in the following image, the net name is set to "Net1".
Assign net
Then repeat this process for the other pad that you want to be connected to this pad. By setting the same net names for pads, Altium will connect them together. Then you can use the routing tool to draw the track.
Routing
  • \$\begingroup\$ When I double click on the pad, it comes up with a similar thing as what is shown in your image. However, I don't have a net information block so I can't see a "Net name" field. I do have the properties block and for the "Net" field, for me it says No Net. I tried to change that but it doesn't let me. \$\endgroup\$ Commented Jan 24 at 23:44
  • \$\begingroup\$ You need to create the netlabel first. I don't have Altium on this computer. I remove the answer, later on, I'll create screenshots of the whole process and put them here. \$\endgroup\$
    – Saadat
    Commented Jan 25 at 7:58
  • \$\begingroup\$ Sorry, it took me a while to find a computer with the Altium on it. I hope it's still useful. \$\endgroup\$
    – Saadat
    Commented Mar 25 at 18:08
