I have uploaded the DS18x20 Temperature
example sketch (unaltered, except I tried multiple pins for the I2C communication) to my proven Duemilanove and my mighty 1284p
On the Duemilanove my two DS18B20
temperature sensors are found and read correctly:
ROM = 28 36 6D 51 4 0 0 75
Chip = DS18B20
Data = 1 D6 1 4B 46 7F FF A 10 43 CRC=43
Temperature = 29.37 Celsius, 84.87 Fahrenheit
ROM = 28 19 6 51 4 0 0 86
Chip = DS18B20
Data = 1 A7 1 4B 46 7F FF 9 10 E0 CRC=E0
Temperature = 26.44 Celsius, 79.59 Fahrenheit
No more addresses.
Whereas the 1284p only says
No more addresses.
No more addresses.
I have not changed the wiring of the sensors; they are connected +5/GND, Data is pulled to +5V with a 2k7 and also to the reading pin, respectively. I have tested multiple pins for I2C communication - they all work on the Duemilanove, none work on the 1284p.
I am assuming some issues with I2C with mighty 1284p
, but maybe someone else has another idea.
Here's the code (the unchanged example sketch, I have been taught to "include the used code, always!", so here it is):
#include <OneWire.h>
// OneWire DS18S20, DS18B20, DS1822 Temperature Example
// http://www.pjrc.com/teensy/td_libs_OneWire.html
// The DallasTemperature library can do all this work for you!
// http://milesburton.com/Dallas_Temperature_Control_Library
OneWire ds(0); // on pin 10
void setup(void) {
Serial.begin(9600);
void loop(void) {
byte i;
byte present = 0;
byte type_s;
byte data[12];
byte addr[8];
float celsius, fahrenheit;
if ( !ds.search(addr)) {
Serial.println("No more addresses.");
Serial.println();
ds.reset_search();
delay(250);
return;
Serial.print("ROM =");
for( i = 0; i < 8; i++) {
Serial.write(' ');
Serial.print(addr[i], HEX);
if (OneWire::crc8(addr, 7) != addr[7]) {
Serial.println("CRC is not valid!");
return;
Serial.println();
// the first ROM byte indicates which chip
switch (addr[0]) {
case 0x10:
Serial.println(" Chip = DS18S20"); // or old DS1820
type_s = 1;
break;
case 0x28:
Serial.println(" Chip = DS18B20");
type_s = 0;
break;
case 0x22:
Serial.println(" Chip = DS1822");
type_s = 0;
break;
default:
Serial.println("Device is not a DS18x20 family device.");
return;
ds.reset();
ds.select(addr);
ds.write(0x44,1); // start conversion, with parasite power on at the end
delay(1000); // maybe 750ms is enough, maybe not
// we might do a ds.depower() here, but the reset will take care of it.
present = ds.reset();
ds.select(addr);
ds.write(0xBE); // Read Scratchpad
Serial.print(" Data = ");
Serial.print(present,HEX);
Serial.print(" ");
for ( i = 0; i < 9; i++) { // we need 9 bytes
data[i] = ds.read();
Serial.print(data[i], HEX);
Serial.print(" ");
Serial.print(" CRC=");
Serial.print(OneWire::crc8(data, 8), HEX);
Serial.println();
// convert the data to actual temperature
unsigned int raw = (data[1] << 8) | data[0];
if (type_s) {
raw = raw << 3; // 9 bit resolution default
if (data[7] == 0x10) {
// count remain gives full 12 bit resolution
raw = (raw & 0xFFF0) + 12 - data[6];
} else {
byte cfg = (data[4] & 0x60);
if (cfg == 0x00) raw = raw << 3; // 9 bit resolution, 93.75 ms
else if (cfg == 0x20) raw = raw << 2; // 10 bit res, 187.5 ms
else if (cfg == 0x40) raw = raw << 1; // 11 bit res, 375 ms
// default is 12 bit resolution, 750 ms conversion time
celsius = (float)raw / 16.0;
fahrenheit = celsius * 1.8 + 32.0;
Serial.print(" Temperature = ");
Serial.print(celsius);
Serial.print(" Celsius, ");
Serial.print(fahrenheit);
Serial.println(" Fahrenheit");
Thank you.
