Shown below is an EMI filter for an AC input. My doubt is when I analyse the inrush current, should I be considering the contribution due to all three capacitors?
a) Differential mode capacitors
b) Common mode capacitors
c) Load capacitors ( In our case, the load is rectifier with bulk caps at the output)
Since these currents might not be in phase, the straightforward addition may not be feasible*. Iam not sure how can the net effect be calculated?
(*I guess, the 90 degree phase difference between AC voltage (across) and current through a capacitor would not be applicable during inrush duration (Since the 90 phase difference is a steady state phenomenon). Please confirm.)
Also would I be getting different inrush values if I measure the phase leg or nuteral leg of AC supply - depending on the additive/subtractive nature of common mode current?
PS: In our existing design we are addressing only the inrush current due to rectifier o/p caps. Iam not sure why the inrush due to EMI filter caps is omitted.
