I have what I hope to be a really simple question I have to ask now as it stopping me sleeping lol.
I’ve added Bluetooth to a 1950s car radio, using 2 SPDT switches (one could be replaced with SPST for power to be fair.) Anyhow, 1 switch basically gives power to the Bluetooth module when pressed in.
The other switch at the same time switches it from the Long/Medium wave audio signal to Bluetooth which is the two throws and the pole the audio output to the volume control.
The volume control knob I’ve had to replace because of space issues however would rather use the original switch as it has better range of control on it, which could be done if I only had 1 SPDT switch that I currently have. I’ve never used transistors before but I believe they can used a switches, and that I could potentially use the 5v supply being switched on as the signal to also switch the audio signal electronically? Replacing the need for an SPDT switch?
Can anyone give a diagram on how I would do this? As with the diagram I can learn alot for future projects and will hopefully understand.
Thanks in advance.
