I think in principle your circuit will work but it is not very repeatable nor flexible because the threshold of the mosfet is not well specified. And the circuit relies on a well defined threshold. Moreover, the switching of the mosfet will be relatively slow as the exponentially varying timing waveform's voltage passes through the rather wide gate voltage range of conduction. In general slow switching is to avoid as it increases power loss in the mosfet. In your particular case as indicated by your schematic it is however not of concern.
If you insist put the circuit into a simulator like LTspice to have a better idea if it will cover the timing range you require.
A more reliable alternative would be the ubiquitous 555 chip which can be found in numerous incarnations such as LM555. Look in this datasheet for the monostable circuit which looks like this
Your switch goes between trigger and GND and you need a pull-up resistor from trigger to supply. The device initiates a cycle upon a falling edge on trigger input. The output goes high during the cycle and back low after the time-out time which is t=1.1 * Ra * C.
So depending on the current requirement of your LED you may get away with just driving the LED in series with a resistor from the output and to GND. Datasheet claims up to 200mA of source current - which is the relevant current in this setup. Be aware of the associated voltage drop between out and supply may be up to 1.6V in that case. This is to subtract in the calculation of the resistor to put in series with the LED. But your circuit suggest only a few mA of current so this will work flawlessly.
If you need more current, you can use the output to drive your mosfet gate directly.
