I have a piezoelectric element, which acts as an accelerometer. Attached to it is a charge amplifier, built based on this documentation. The op-amp is the TL081.
The PZT element is simulated based on a model, where C2 is the transducer capacitance, R3 is the leakage resistance, and C3 is the stray capacitance.
Per my understanding, the charge amplifier should provide a "gain" of -C2/C1, as Vo = -Qp/Cf, and Qp is correlated to the transducer capacitance C2. I am producing an AC signal with offset of 0V, so I will simplify this gain to C2/C1.
My issue is that the charge amplifier does not amplify on most lower frequencies. According to my understanding, the cutoff frequency should be (22010^-121.210^62pi)^-1 = 602Hz. However, I am experiencing no amplification until at least 3.5kHz. The peak is still 6kHz.
This is currently being built on an op-amp.
Things I've tried:
- Swapping the Op-amp. No effect.
- Changing the PZT element into a sine wave generator to simulate the sine wave. No effect.
- Swapping the parts to confirm the value of the resistor/capacitor 220pF and 1.2MOhm. No change.
Please let me know if more information is required.
