I have the following circuit for controlling an engine alternator regulator.
When the regulator sees vBatt on it's input it enables a specific CC/CV charging profile.
I have designed a, (untested), circuit, (which I hope is right), to turn the charge signal on/off and also have it default to off when the engine ignition is turned off.
What I would like to do is integrate the blue circuit into the logic. If the blue circuit is switched off/goes open circuit, by the BMS then I would like the relay to also switch off. This will require the user to consciously enable charging after a BMS disconnect, rather than have it automatically restart if the BMS decides charging is OK.
I believe that I am looking for a component that I can insert at position X which is controlled by the blue circuit. As the output is only 10mA I can't use a standard relay, which would not be ideal anyway, due to excessive power draw from the coil.
Ideally also, the relay should not be able to be engaged if the BMS output is open circuit.
Thanks
Notes: All systems have a common ground reference. vBatt and vIgnition is 9 - 15v
