The GPIO on ESP32 (S3) are all 3.3 V logic. I want to control an ESC for a drone. The manufacturer says:
The ESC will use a standard 5 V PWM signal at 50 Hz between 1100 µs and 1950 µs. 3.3 V output may not read or cause misreads on the ESC.
If you have used the TXS0108E logic shifter, do you know if it will change my output frequency even if I programmed the output of the ESP32 to be 50 Hz like the manufacturer said?
