I have limited experience with USB C and I want to design a board which needs to charge both a smartphone and another subsystem which draws around 1W. I have read that by just connecting a 5.1k resistor to each CC pin of the USB C female receptacle for the power in I can "trick" the wall adapter to give me up to 15W, without using any other specialised USB Type C PD integrated circuit. Also, would the phone (which needs to connect to the "USB C TO PHONE" female USB Type C receptacle) be charged with, let's say, 14W with only the VDD and GND pins connected to its receptacle?
Also, the rest of both receptacle's pins should be left floating, right?
I'd like to mention that I need to use this configuration, with only one USB Type C for power input and the phone charged via the board.
