I'm trying to charge a large capacitor bank (C1) with a resistor (R1) and when it's mostly charged, activate a p-FET (M1) using an op-amp comparator. I built a PCB but the p-FET isn't turning on.
I simulated the circuit in LTSpice and it works as I expected it to, the only difference in LTSpice is the p-FET I'm using on my PCB: IXTA44P15T Vds=-150V, Rds(on)=0.065, Qg=175nC isn't in LTSpice so I used a comparable one:
RSJ250P10, Vds=-100V, Rds(on)=0.045, Qg=60nC
Here are the voltages I'm getting on my PCB with a DMM: ~92V on the p-FET gate and 0V on the n-FET drain.
I can watch the circuit charge up and see the n-FET's drain drop from 12V to 0V when enabled, I'm just not sure why the p-FET won't turn on. The voltages tell me there's no current through R3, and ~280mA through R2 which has to be coming from the p-FET gate. 280mA = 280mC/s so with Qg=175nC, the gate should be discharged in roughly 0.6ms
Also, for some stupid reason I bypassed R2 but as soon as M2 turned on - it blew up.
I feel like I'm missing something extremely simple but I've triple checked my footprints and layout and all seems correct. Here's the output of LTSpice if it helps
