I am trying to create a H-Bridge to power a TEC. Each of the half bridges can be used as a synchronous buck converter, while the other side is grounded.
The frequency and duty cycle are controlled from an STM32G474 at 1MHz.
I have added diodes across the MOSFETs, so that it can be used as a normal buck regulator.
I am now trying to use it in a synchronous mode but am having trouble, I believe I am seeing some shoot-through and I need to adjust my dead-time, as the driver doesn't have any built in. My oscilloscope bit the dust the other day making this a little tricky to diagnose...
Before I start adjusting the deadtime I want to make sure that I am driving the MOSFETs as hard as I can, to potentially decrease the required deadtime.
I am using UCC27289 drivers and PSMN2R8-25MLC MOSFETs. With a 12V gate drive voltage and a 10 Ohm gate resistor.
The UCC27289 drivers have a peak output current of +-3A, so 12/3 = 4 Ohm gate resistor, I currently have 10 Ohms, but can put 2 in parallel and get 5, which should be close enough.
However on quite a few posts I see a reverse diode in parallel with this gate resistor, I have linked one from Mark Harris on Altium here. When the gate of the MOSFET is connected to ground through the gate driver, there is now no resistance to limit the gate current, surely this will violate the peak current rating on the driver?
So to get the fastest switching possible should I use a 4 Ohm gate resistor by itself, or use a combination of a 4 Ohm resistor and a reverse diode?
