We have an AC circuit with rms voltage V, and resistor R. Assuming that the circuit does noy contain any reactive components, Z=R therefore the rms current flowing in the circuit can be obtained by I = V/Z = V/R. If we add reactive component(s) to the circle, we expect that Z will increase, therefore less current will flow in the circuit after the change.
I have a problem with this statement: "In an electric power system, a load with a low power factor draws more current than a load with a high power factor for the same amount of useful power transferred."
How is this possible when the current in the second circuit was lower? Also, how can a circuit 'draw' more current, if the value of the current is fixed and can be found after calculating impedence using ohm's law? Would appreciate to have a sample circuit to demonstrate this.
