I am looking to design a custom RFID antenna which operates at 13.56 MHz. I have designed the antenna using the NFC Design tool (link). Please see the parameters below:
Antenna parameters
Figure 1: Antenna parameters
On top of that I ran some simulation in LTspice to compare the resonance frequency of the antenna circuit using "Antenna model" and successfully confirmed that the 96 MHz is correct.
Antenna model
Figure 2: Antenna model
This is the layout in Kicad PCB designer:
Layout in Kicad
Figure 3: Layout in Kicad
In the first go I was interested in only the antenna parameters thus the tuning circuitry falling left to the RF3 SMA header is detached (no R4 and R5 resistors placed).
Just received it from the manufacturer. In the meantime I took a hold of a NanoVNA device so that I can physically check the antenna parameters roughly. Calibration took place as required, also tested a 2.4 GHz standard antenna too to make sure the VNA is working properly and the the magnitude diagram showed a negative spike around 2.4 GHz, so it's ok.
Finally I arrived to the point to connect the VNA to my custom antenna board, ANT_IN header. My expectation was to see a similar magnitude diagram similar to what I saw in my LTspice simulations. I did not see any negative spike at the theoretical resonance frequency (96 MHz) so I expanded the measurement range to what is going on:
VNA measurements
Figure 4: VNA measurements
It seems that the resonance freq. is a little above 1 GHz which is far off the desired ~100 MHz theoretical resonance freq. with another order of magnitude.
Figure 5: VNA measurements between 1-100 MHz
Unfortunately no resonance freq. here. Moving the cursor in the vicinity of 13.56 MHz the inductance value has proven to be ~2.11uH. This is apprx. half of the calculated value (1337 nH).
I cannot wrap my head around the fact what goes wrong honestly, but I must be making some mistake big time.
Please explain what I might be doing wrong.
  • \$\begingroup\$ What is your question? There is no question stated in your post we don't know what you want us to answer. \$\endgroup\$
    – The Photon
    Commented May 31 at 14:57
  • \$\begingroup\$ The nanoVNA indicates -28.2 Ohm + 2.11uH which is outside the Smith diagram and would suggest the circuit is oscillating. Did you redo the calibration for the new frequency span? The number of measurement points is limited to 101 which means with large frequency spans (e.g. 1GHz) you will very likely miss the rather sharp self resonance frequency of the coil. \$\endgroup\$
    – Raonoke
    Commented Jun 1 at 0:02
It seems @Raonoke, you are right.
"The nanoVNA indicates -28.2 Ohm + 2.11uH which is outside the Smith diagram and would suggest the circuit is oscillating. Did you redo the calibration for the new frequency span? The number of measurement points is limited to 101 which means with large frequency spans (e.g. 1GHz) you will very likely miss the rather sharp self resonance frequency of the coil."
I did not do any recalibration on the new span before. After doing so I got this: enter image description here
Figure 1: Resonance frequency at 81 MHz after recalibration on the new freq span
Only ~10 MHz off the theoretical 96MHz, which deviation might be acceptable I think.
Thank you so much for your help.
This is (I think) a loop antenna. At the operating frequency it will be inductive that will need to be matched to the source.
I suggest using the nanoVNA to measure the inductance at the intended operating frequency. Check to see if it is close to the design value.
While cheap, the nanoVNA (when calibrated, when operated correctly accounting for the potential existence of parasitics, and if you get one that is operating) is good enough for this sort of thing.
