Help me to understand how this oscillator works. Although I mostly want the vintage computer to work, I also want to understand how this circuit functions.
I attempted to recreate the oscillator on a breadboard, but did not get it to oscillate. I verified the crystal works by connecting it to a signal generator with a 50 ohm resistor in series. At 9.808 MHz, the Vp-p increases dramatically. I also verified the capacitors (up to 1 KHz). My equipment and supplies are reasonable for a hobby lab (o-scope. sig-gen, LCR meter, good supply of components).
Some questions:
- How can I test the transistor?
- Am I testing the crystal properly?
- How does this oscillator oscillate?
Background
This is the oscillator from a 1980's vintage Hewlett Packard computer. Mine has a bad transistor Q1. Cold spray on Q1 allowed the computer to operate normally. Next, I removed jumper W1 and injected a 9.808 MHz square wave into XW1-1, and the computer operated normally for 24h. I also measured at U2-2 (the oscillator output / input to NAND). The peak was around 2.4 V, and the frequency was correct at 9.8 MHz.
Good people at the HPSeries80 group identified the transistor as a 2N3563 with these properties
Type# | Dec | LeadID | Vcbo Min | Vceo Min | Vebo | Icbo | Vcb | Hfe | @Vce | @Ic | Cob-Max | fT-Min |
PN3563 | NPN RF OSC | EBC | 30v | 12v | 2.0v | 50nA | 15v | 20 to 200 | 10 | 8.0mA | 1.7 | 600Mhz |
I didn't ask for the crystal oscillator properties.
The oscillator
From the HP85A schematic
My best recreation (disregard crystal parameters):
and in Falstad
