I know that it can also be estimated by extrapolation, but I would like to determine the Early voltage from the Ebers-Moll equation. The equation I want to use is: Where Is = saturation current. Ut = Thermal voltage, Uf = Forward voltage, Ic = Collector current, Uce = Collector-Emitter voltage
I tried to determine Is from the behavior of the B-E PN junction, which turned out to be an extremely small value for the BC547C Is ~ 4.2741E-14.
If I calculate with this value, I get a surprisingly accurate value for Uf. However, if I calculate with this saturation current, a very large value is obtained for the early voltage.
My problem is determining the saturation current. How can I determine the saturation current?
Is
is at for a model. Even in the far more sophisticated case of Spice models that take into account the formation of emitter-base surface channels, the recombination of surface carriers, and the recombination of carriers in the emitter-base space-charge layer. The same is true forVA
. And for the emission coefficient. Is that all this is about? Just getting a simulator output that you can read? \$\endgroup\$Is=1E-14
and an emission coefficient of1
(which means 60 mV per decade change of current) and an Early Effect voltage ofVA=100
. This circuit and plot uses a green arrow to demonstrateIs
and a blue circle and lines to show that there is just 60 mV per decade change of the collector current. All in one chart. And this chart shows the Early Effect is atVa=100
, just as the model says it should be. So what's going on? What are your questions here? I'm flummoxed. \$\endgroup\$
