I'm using STM32CubeProgrammer to flash an MCU.
But after flash completes, to reset and run the MCU I have to interact with NRST pin by a push button.
Is there a way that right after the flash the MCU starts a reset automatically?
  • \$\begingroup\$ Through which interface you are uploading? USB/DFU, UART, or by using some JTAG/SWD adapter? \$\endgroup\$
    – Justme
    Commented Jul 18 at 13:19
  • \$\begingroup\$ SWD using st-link V3 \$\endgroup\$
    – cm64
    Commented Jul 18 at 14:07
Under the Erasing & Programming tab, you have to enable the 'Run after programming' option.
Source: UM2237, page 28
  • \$\begingroup\$ It would be a great solution but my experience also is that for some reason it does not really go to run code after programming so I never used it or have tried it since. May depend on through which interface you upload the firmware. \$\endgroup\$
    – Justme
    Commented Jul 18 at 13:17
    \$\begingroup\$ @Justme If the GUI fails, I would try the command line interface (STM32_Programmer_CLI.exe). It gives you better control. Check out the --start and -rst commands. \$\endgroup\$
    – Velvet
    Commented Jul 18 at 13:33
    \$\begingroup\$ The answer worked for me. But you need to click Start Programming instead of Download. \$\endgroup\$
    – cm64
    Commented Jul 18 at 14:08
  • \$\begingroup\$ Thanks for the feedback \$\endgroup\$
    – Velvet
    Commented Jul 18 at 14:35
