I had an LM2576 (ADJ variant) lying around and tried building a buck, and then an inverting buck-boost converter, purely for academic purposes. I have next to no prior experience with converters (or power management in general).
For the inverting buck-boost, I tried to follow the data sheet, but didn't have the right inductors, nor the right diode, but I thought that even though it may not work particularly well, it should work to some degree, right? Instead of the suggested 68uH, I used a 330uH power inductor rated at 800mA, and instead of a Schottky diode I used a regular one rated at 1A (also tried standard 1N4148). The goal was to make -5V from 9V, give or take with a load of no more than 50mA or so.
Background: It didn't work initially (had slightly different parts here and there), and on my lab PSU it looked like it short circuited. Some searching suggested that I need different inductor or output capacitor values, and it's totally important that they're 100% correct, and a Schottky diode, so after messing around with the parts I have at hand, I was getting partial success. Turns out that was a red herring, after reading the datasheet again (in particular the topic about the undervoltage lockout circuit), I tried disconnecting VIn, then turning on the PSU and letting C1 charge, and then connecting VIn, and it worked despite my borked parts.
It appears that the problem was that the lab PSU was ramping up its output voltage too slowly, in combination with the overcurrent protection kicking in at 500mA, so output voltage dropped below 2V while the circuit was drawing a constant 500mA, and the LM2576 never had a chance to boot up. Depending on the inductor and capacitor used, the output is between 0V and around -2V or so.
My question is, when it's drawing a steady 500mA in the broken state, where exactly is all that power going? If the output is 0V, then it can't be the diode, so it must be in the LM2576 itself, but where exactly? How come it's not enough to turn on the circuit properly? My only guess is that the LM2576, being advertised as a pure buck-converter, regulated its duty cycle close to 100% (my intuition says a buck-boost converter should operate around 50% to 60%), so at close to 100% the inductor essentially only sees DC and nothing really happens. I don't have an oscilloscope (yet), but my multimeter wasn't able to pick up any frequency at the VOut pin in the faulty state (but was able to pick up the switching frequency when the circuit works correctly), which would support this theory.
To be clear, I know that several things are going wrong here, but I would like to understand why I'm observing what I'm observing when it's in this wrong state.
If that is the case, then how do commercial or industrial applications reliably protect against entering in this faulty (and potentially dangerous) state in the first place? Even with an undervoltage lockout circuit present, the supply could be too weak, no? (imagine a battery powered device)
