You didn't specify the motor, but here is a general idea of a circuit that uses an auxiliary 24V supply and drives the BJT with a TIP120 darlington. The motor is represented by the 1Ω resistor so the maximum current would be 12A (of course you can't get all the way there because the BJT has some voltage drop).
The purpose here is to show you some idea of the power dissipation in the various components:
The top (violet) trace in the top plot pane shows you the motor voltage, which tops out at around 11V.
The gray trace in the middle plot plane shows you the current from the 24V supply, which is maximum at a bit more than 2A
The bottom pane shoes you the dissipation in the various power components.
The blue trace is the pass transistor dissipation, which is maximum at 6V on the motor, as you would expect, at a bit less than 35W.
The red trace is the dissipation in R4 which is maximum at maximum output voltage- at more than 21W.
The green trace is approximately the dissipation in the TIP120 which peaks at at almost 9W.
All in all, a pretty ugly combination- requiring heat sinks and massive parts as well as an inconvenient 24V supply at substantial current.
A PWM solution in this power level could require minimal heat sinking.
BTW, a brushed DC motor will have no-load RPM proportional to ESP output with this kind of circuit, however there will be minimal braking since the circuit shown does not sink current.
