I have one hx711 module connected a 200 kg load cell and I'm measuring a high current consumption: around 13mA where the datasheet says it should be around 1mA.
Cabling is as follows: usb to the mcu (around 4.9V), mcu raw/gnd to the module Vcc/Gnd and data/clock pin to some consecutive pins on the mcu. Load cell black to hx711 E+, white E-, red A+, green A-. I can read the values fine and accurately. I have 4 load cells bought together on Aliexpress (specs below).
Here are the things I tried which didn't had any effect (high current):
- tried each 4 load cell separately.
- tried channel B but couldn't read any meaningful value
- tried different microcontroller: pro micro and esp32.
- tried different library: RobTillaart/HX711 and MajicDesigns/MD_HX711.
- tried the hx711 modules from berrybase.ch (trusted) and my own design (based on Sparkfun).
Load cell: Berrybase module looks as the usual "cheap" hx711 module I wasn't able to try different types of load cells yet.
Here are measurements I have done myself on pro micro with berrybase module: R between white-black is ~380 ohm, green-red is ~330 ohm. Current consumption taken between pin RAW and the module Vcc is 13mA except when it's in sleep (power_down) it's 0uA (cannot measure). If I unplug the load cell but still active, it's around 1.8mA. Measuring current on E+ is ~10mA, where for A+/A- I cannot measure it's 0mA. I have some voltage measurements too if that can help.
At this point I'm unsure where is the issue even after trying so many things, should I suspect a problem with the load cell themselves? I'm also concerned about the load cell wiring as the colors don't look standard but this is what the seller wrote and I can read values fine and accurately (is that something to question?).
Here are the specifications of the load cell provided by the Aliexpress seller (if that helps): Input Impedance :405 10 Output impedance :350 3 Insulation resistance :5000M (100VDC) Excitation voltage :5VDC ~ 10VDC
MAX working voltage :12VDC Temperature compensation range :10 ~ +40 Operating temperature range: -20 ~ +60 Temperature effect on zero 0.03% F.S/10 Temmp.effect 0.02% F.S/10
