I have designed a mains powered flyback. As a newbie I am well informed about the danger of mains voltage if measured incorectly.
Still I want to measure a few points in my circuit to better understand it.
I am aware that isolation is a must to deal with mains voltage, therefore I am looking for an isolated differential probe.
There are 3 options that I found:
- Hantek HT8100 "Isolated Diff Probe" for 200€ https://www.hantek.com/products/detail/6163
- Pico TA041 "Active Diff Probe" for 400€ https://www.picotech.com/accessories/active-differential-high-voltage/25-mhz-700-v-differential-probe
- Rigol PHA0150 "Diff Probe" for 800€ https://rigolshop.eu/accessories/probe/pha0150.html
My question is:
- Some of the options do not mention if it is "isolated" (TA041 and PHA0150) but they write it as measurement scenario for use "HV isolation measurement". Can I still use this to safely measure mains?
- My osciloscope is from Rigol, and it is recommend to use the PHA0150 from the same brand Rigol for diff probe so that no compability issue arise. The HT8100 offer the same specifications with a fourth of the price and mention that it is "isolated". What aspect should I be worried of in terms of compability compared to if its isolated or not?
- Is it safe to use TA041 "Active Diff Probe" for mains? does "Active" also provide protection for measuring mains?
