I have a battery charging circuit that works fine except that I want to turn off the battery charger IC when the batteries are removed. When the charger IC is enabled and charging, it's outputting voltage into the battery/circuit. Anything I've tried so far doesn't work as even with batteries removed, most charger ICs still output voltage, even in a fault state (I have eval boards for BQ25306, MP2515, etc - they all do this).
Are there ways to detect when the actual battery is removed outside of mechanical/optical solutions?
  • \$\begingroup\$ What exactly are you trying to do? Why is leaving the charge IC on even a problem? Most charge IC's have a "shut down" pin to manage what you are describing. \$\endgroup\$
    – MOSFET
    Commented Sep 5 at 21:06
  • \$\begingroup\$ Sounds like you're powering your circuit from the battery while trying to charge it. If they're Li-ion that's a no-no. \$\endgroup\$
    – Finbarr
    Commented Sep 5 at 21:34
    \$\begingroup\$ Please share a schematic to avoid us speculating about how things are wired. \$\endgroup\$
    – Attie
    Commented Sep 5 at 21:44
  • \$\begingroup\$ Yes, most charger ICs have an enable pin, but I want to shut it down automatically if the battery is missing. The use case is a person removing a battery during a charging phase. Hopefully this makes sense! \$\endgroup\$
    – Sean
    Commented Sep 6 at 22:07
The problem
... with current
It is difficult to determine the absence or presence of a battery by measuring the current because in both cases there is an open circuit. In the first case, it is a true open circuit (infinite resistance), while in the second case it is a virtual open circuit (an oppositely connected equivalent voltage source).
... with voltage
It is difficult to determine the absence or presence of a battery by measuring the voltage because the two voltage sources (the charger and the battery) are connected in parallel so in both cases there is the same voltage.
Solution
To solve the problem with voltage, we need to somehow decouple the two sources from each other. For example, we can do it by connecting a diode between the charger and the battery (with the anode to charger and the cathode to battery). Then, when the battery is removed, there will be no voltage after the diode.
To detect this high-impedance state, we can connect a pull-up resistor between it and a higher voltage source.
Operation
Charging battery
The diode is forward biased. The battery voltage is lower than the charger voltage, and it determines the indicator voltage VIND = 5 V.
Charged battery
The voltage across the diode is zero so it is off. The battery voltage is equal to the charger voltage, and determines the indicator voltage VIND = 6 V.
No battery
The diode is backward biased. The indicator is connected through R2 to the additional V1 voltage. There is no current flowing, no voltage drop across R2, so the indicator voltage is VIND = 10 V.
More experiments
  • Try the circuit above without a diode; it might work depending on what is inside the charger output.
  • Monitor the (change in) voltage at the charger output. It should change (increase), even slightly, when the battery is removed.
    \$\begingroup\$ Neat idea, thank you. I would imagine the charger IC would need to sense the actual battery using whatever pin is dedicated for this and the diode would be on the output side of the IC? \$\endgroup\$
    – Sean
    Commented Sep 6 at 22:13
    \$\begingroup\$ I can't say for sure, @Sean... Let's just give it a shot, like we often do in life :-) \$\endgroup\$ Commented Sep 6 at 22:18
  • \$\begingroup\$ Heck yeah! I believe I can test this with an eval board I have. :) Thanks again. \$\endgroup\$
    – Sean
    Commented Sep 6 at 23:06
Monitor current. A fully charged battery left to Float on a charger will have a small amount of charge current flowing (battery self-discharge current). Detect when the current drops to zero amps. You know you have an open circuit or a missing battery.
  • \$\begingroup\$ My concern is during a charging phase current will be present, so it will fool any attempts to monitor current. \$\endgroup\$
    – Sean
    Commented Sep 6 at 22:09
Once per minute turn off the charger for very small time (like 1 sec) and check if battery is presented. Simple RC oscillator can do the timing.
  • \$\begingroup\$ Thinking outside the box - interesting idea, thank you. \$\endgroup\$
    – Sean
