I am trying to construct Automatic switching power supply, which switches between 5 V power source (produced from 9 V DC SMPS Power supply) and 5 V Battery Power from the Boost converter (produced from 3.7 V 18650 Li-Ion Battery) and the Relay output is connected to Vin pin of Nodemcu v1.0 ESP-12E with 160 mA current consumption.
5 V Relay is used to switch between two power sources and the output of 5 V Relay is given as input supply to the Vin Pin of Nodemcu v1.0 ESP-12E. Nodemcu v1.0 ESP-12E consumes 160 mA current during operation.
But due to slow relay switching speed, Nodemcu v1.0 ESP-12E is loosing power for 5 seconds and i have used 4700 Micro Farad Capacitor between Vin and Gnd pin of Nodemcu v1.0 ESP-12E. But the problem still exists.
I have Googled for Solutions. But they are not useful for me.
MCP73871 PowerBoost Chip costs around 800Rs which increases the cost of the project. Is there any low-cost reliable solution for switching between two power sources without interrupting power to Nodemcu v1.0 ESP-12E ???
LTC4412 Low Loss PowerPath™ Controller is not available in India. So I can't implement the Automatic switching circuit mentioned in this website.
Using two diodes for OR operation copied from this website, looks problematic, if there is high power consumption from Nodemcu v1.0.
Please suggest me some working solution which can safely provide 5 V, 500 mA current to Nodemcu ESP-12E Vin pin.
