I'm researching NiMH batteries, and I understand that these batteries charge via CC, but what I don't understand is what happens if you have a CC source, but the voltage goes above the max battery cell voltage, or if your voltage is too low to fully charge the cell.
Example 1: I'm charging a single cell NiMH, rated for 1800mAh with 180mA of constant current with a max supply voltage of 5V. What happens when the cell reaches 1.4-1.5V? Will the power supply voltage match the cell voltage?
Example 2: I'm charging a single cell NiMH, rated for 1800mAh with 180mA of constant current this time with a max supply voltage of 1.1V. Once the cell reaches 1.1V, will the cell just be in a state of equilibrium with the power supply and basically just stop charging?
