I'm designing an adapter for a vintage 20mA current loop interface, transmitting serial at 2400 baud. It's for Digital Equipment computers from the 1970s and 1980s, for a museum. We don't need to a general solution, just one for this particular board: a DL11-A Asynchronous Serial Line Interface. Our primary goal is of course to protect the museum pieces, which are from about 1978 onwards.
Solution
My idea is to use a simple 4N35 (datasheet) optoisolator circuit, with current limit resistor, for both input and output, with complete separation of power supplies. EDIT to add: the cable is at most 20 or 30 cm, more likely 5 cm.
The question: Do I need anything more sophisticated?
See below for details of what we're interfacing to and my simulations.
Circuits we're interfacing to
The input and output circuits are as follows
The input comes in at labels
K
(+5V) andS
(-15V) and comes out atH
which feeds a 7413 Schmitt gate with 10K pullup atE
.The output is a PNP pull-up to +5V on
AA
and -15V onKK
.A D664 diode is apparently like a 1N3606 or 1N4153 (datasheet)
6534D transistor is like MPS6534 (datasheet)
Edited from DEC manufacturing drawing microfiche, PDF page 9
Simulations
I wasn't sure how to simulate these exactly (especially the optocouplers), but nevertheless this is what I tried. In the input it looks like R102 can be anywhere from about 1K to 5K and still get good TTL levels at E
. In the output, I selected R201 as 1K to get about 10 mA across D201.
