I have a rail of unidentified SOIC-8 ICs with marking
501
115
Nothing else. No manufaturers logo, no nothing. Does anybody know what this could be?
edit
(picture added)
At 3mm they're quite high for SOIC-8, so they could be optocouplers or so?
Grid is 5mm. (Yes, I know the devices aren't properly aligned, but I did this on my scanner with a sheet of paper over the devices...:-))
update/conclusion
It's almost certainly an Agilent HCPL-0501. The marking matches completely: the 501
refers to the type number, the 115
means week 15 of the year 2001. And the date code appears below the type number (which was a problem with the TR115).
Also diode tests all pass. The 5-6 test which passed was an error; I probably held the testprobe on pin 6 and 7 simultaneously, and 5-7 is the transistor's base-emitter diode.
Thanks for all the replies.
