I've got a messy security panel that needs cleaning up badly, as I need to connect another PCB for remote access and can't get the wires to reliably stay in place:
If you look at the black, red, green, and yellow terminals, they already have three separate wire (pairs) connected!
So far, a terminal strip like this is the only solution I can come up with. However, I'd have to add an additional bus bar across the terminals that need to share a signal, which just adds to the size of the bar needed and is a little inconvenient:
There's always Phoenix Contact terminal blocks like the following:
However, at over $10 each from Digikey, it's a pretty expensive (though elegant looking) solution.
I guess I'm looking for something like the following photochopped image?
Note that I'd like a bus bar that connects the columns of terminals...
Can anyone suggest other options?
