the capacitor acts like a variable-resistor turning the circuit into a voltage divider.
...while it [C1] accumulates charge, its resistance slowly increases...
This is a little bit valid, but I think maybe not quite the way to think of it, at least if you are considering the time domain. It's quite common to think of capacitors as "variable resistors" where the "resistance" is a function of frequency, but not time. This is the basis of AC circuit analysis, and in this case it would be properly called reactance or more generally impedance, not resistance. However, the wording of your statement, especially the second part of what's quoted above, suggests this is not what you had in mind.
First, think about what resistance means. There's Ohm's law:
$$ V = IR $$
or equivalently:
$$ R = \frac{V}{I} $$
And there's the definition of the ohm:
$$ \Omega = \frac{V}{A} $$
So, resistance relates how much current you get for some voltage. Often, such as when we are talking about the input resistance to a circuit, we generalize this to just the change in voltage and current:
$$ R = \frac{\mathrm{d}V}{\mathrm{d}I} $$
We consider just the change, and model any constant offset with an ideal voltage source. See Thévenin's theorem.
Anyhow, consider that your RC circuit is a black box. Consider that the voltage across the capacitor is 0V, and you change the input voltage from 0V to 1V. The current will change from 0A to 0.01A. So, the input resistance is:
$$ \frac{\mathrm{d}V}{\mathrm{d}I} = \frac{1V-0V}{0.01A-0A} = 100\Omega $$
Now you leave this thing running for a while. The voltage across the capacitor has reached 1V, and there's no input current. Now you change the voltage from 1V to 0V. The current will change from 0A to -0.01A. So, the input resistance is:
$$ \frac{0V-1V}{-0.01A-0A} = 100\Omega $$
What if the capacitor starts charged to 1V, and we change the input voltage from 0V to 1V? The current will start at -0.01A, and end at 0A. So:
$$ \frac{1V-0V}{0A-(-0.01A)} = 100\Omega $$
In fact, it doesn't matter what values you pick for the change in voltage, or the initial state of the capacitor. The input resistance is always \$100\Omega\$. So if the capacitor is acting as a variable resistance, it's doing a good job of evading mathematical reasoning.
I would think of it this way: by Kirchhoff's voltage law, the sum of the voltages across the resistor and the capacitor must equal the input voltage:
$$ V_{in} = V_{R1} + V_{C1} $$
which means that the voltage across R1 is the input voltage, less the voltage across C1:
$$ V_{R1} = V_{in} - V_{C1} $$
If \$V_{in}\$ had been 0V for a long time and is suddenly 1V, then \$V_{C1}\$ will at that instant be 0V, and \$V_{R1}\$ must be 1V. The current through R1 is still given by Ohm's law, into which we can substitute the previous equation:
$$ I_{R1} = \frac{V_{R1}}{R_1} = \frac{V_{in}-V_{C1}}{R_1} $$
So what's really happening here is that as time goes on, \$V_{C1}\$ approaches \$V_{in}\$, thus reducing \$V_{R1}\$, thus reducing the input current, thus reducing the current available to further charge/discharge C1. There's no resistance changing here. What's changing is the voltage across R1.
Assuming, of course, that the output current is negligible, which is only true when it's connected to a high impedance. As you have the circuit drawn, it isn't connected to anything, which is an infinite impedance, and current is 0A, so this assumption holds.
You will further notice that if the input voltage is changing quickly relative to how fast C1's voltage can change (which is limited by the current, which is limited by R1), then C1 never has much opportunity to catch up with the input voltage, and so never has much of a chance to oppose it. Thus, if you consider the AC voltage and current, then C1 does less to impede the input current if the input frequency is high than it does if the input frequency is low. This is the basis of AC analysis, and leads us to the concept of capacitive reactance:
$$ X_C = \frac{1}{2\pi fC} $$
Here, you can see that the reactance of a capacitor depends on the frequency \$f\$, so if you are viewing this RC circuit as a low-pass filter, C1 can be viewed as a variable impedance as a function of frequency:
$$ X_{C1}(f) = \frac{1}{2\pi f (1\mu F)} $$
By forming a frequency-dependent voltage divider, a filter is formed. However, this is quite different than the time-domain statement made earlier, "while it [C1] accumulates charge, its resistance slowly increases."
