I'm designing my first PCB but I'm a bit stuck on how I'm going to use it.
At the moment my design is on breadboard with a single input and output.
I want to use my PCB as like a little module where I can just put a input wire into it. Also how I would connect up power and found etc.
I thought of using a row of female jumper connectors just like the black strips on an arduino and then I can just insert the wire inputs into the headers. However it seems like its not such a standard component and farnell and rs don't stock the jumper.
So it got me thinking what is the commonly used connector or method just for simple input and output.
