Why some of JFET preamp's for guitars don't bias the gate to Vgs(off)/2 and just reference it to ground? (Setting Zi)
This also lead to just direct coupling the guitar output to the gate.
As far as I understand with N-JFET's one should apply a negative voltage up to Vgs(off) to control the current the channel. And that on the ohmic region near to Vgs=0 the transfer curve becomes more non-linear.
The direct coupling non-biased design would mean the preamp or voltage buffer would be working on the Vgs=0 non-linear zone and that on the positive semi-cycle of the input sine wave the gate will be forward biased and would not make the channel less resistive (since Ids is already max and the channel saturated) then the output would be quite different from the original.
One example of these designs:
Ruby: MPF102 input buffer for a LM386
Explanations like this one has a DC bias on the gate (that doesn't matters on the AC analysis though).
As far I have figured out if we put our reference on the Source, Rs is biasing both Source and Gate, making the Source more positive than the gate, and the Gate as negative as Vs.
But then on the Ruby circuit, taking the Source as reference, the Gate would be at -9V above the -8V needed to reach cut-off voltage on a MPF102 and -6V with a 2N5457. A positive semicycle above 1V should make a difference but a negative semicycle won't.
My approach is wrong? I know that DC and AC analysis should be done way different from this, but I don't understand the physics mechanics that are working here.
EDIT:
Setting aside that learn how things work is a good thing, I wanted to understand this to replace that MPF102 with an 2N2302 with smaller specs than the MPF102: Idss=5mA; Vto=-4V. (MPF102 and 2N5457 are not available here) I was worried if I would have to change values to achieve a proper polarization since my signal in a worst case scenario goes as high as 2Vpp and the MPF102 Vto is -8V. I understood that it was a voltage follower but failed to understand the inner workings so these questions came up.
