What would be the difference in using a 7-segment decoder with active-high outputs vs active-low outputs, to driver an LED display?
1 Answer
Some 7 segment displays are common anode, which require a decoder with an active-low output. Others are common cathode, which require an active-high output. Choose the decoder appropriate to the display that you want to use.
\$\begingroup\$ @stevesy It seems common-anode displays are more common, as the decoder circuitry in bipolar 74xx series devices drew more power when driving common-cathode displays. Whether this is also the case with CMOS decoder ICs like the 74HC/HCT series, I am not certain. \$\endgroup\$– MattyZDec 6, 2013 at 5:51
