I made a big mistake: I've written a small sketch just to play with my new arduino mega 2560. The sketch worked fine but a bit slow, so I thought that if I increase the baud-rate I will get faster communication to my computer. So I changed the baud-rate to 14400 (in the Serial.begin();
statement).
Now I'm not able to upload sketches any more, and I don't know how to solve this, I tried to burn the bootloader again but I don't know how to do it.
The sketch:
const int pin_in=A0;
const int cols=151;
int value;
int prev;
void setup() {
Serial.begin(9600);
// Serial.begin(14400);
void loop() {
value=analogRead(pin_in);
value=map(value,0,1023,0,cols);
for (int i=0; i<cols; i++){
if (i==value){
if (value==prev){Serial.print("|");}
else if(value<prev){Serial.print("/");}
else if(value>prev){Serial.print("\\");}
} else if (i%30==0){Serial.print("|");}
else {Serial.print(" ");}
Serial.println("|");
prev=value;
delay(1);
When I try to upload my sketch (or any example sketch) I get error while opening /dev/ttyACMX although its present before trying to upload the sketch.
processing.app.SerialException: Error al obrir el port sèrie "/dev/ttyACM0".
at processing.app.Serial.<init>(Serial.java:178)
at processing.app.Serial.<init>(Serial.java:77)
at processing.app.debug.Uploader.flushSerialBuffer(Uploader.java:77)
at processing.app.debug.AvrdudeUploader.uploadViaBootloader(AvrdudeUploader.java:175)
at processing.app.debug.AvrdudeUploader.uploadUsingPreferences(AvrdudeUploader.java:67)
at processing.app.Sketch.upload(Sketch.java:1671)
at processing.app.Sketch.exportApplet(Sketch.java:1627)
at processing.app.Sketch.exportApplet(Sketch.java:1599)
at processing.app.Editor$DefaultExportHandler.run(Editor.java:2380)
at java.lang.Thread.run(Thread.java:744)
Caused by: gnu.io.UnsupportedCommOperationException: Invalid Parameter
at gnu.io.RXTXPort.setSerialPortParams(RXTXPort.java:213)
at processing.app.Serial.<init>(Serial.java:163)
... 9 more
processing.app.debug.RunnerException: Error al obrir el port sèrie "/dev/ttyACM0".
at processing.app.debug.Uploader.flushSerialBuffer(Uploader.java:101)
Is there a way to reset an arduino mega 2560 board?
dmesg
. Doesls -l /dev/ttyA*
actually show anything when the Arduino is connected? BTW: My Megas register as/dev/ttyUSBn
. \$\endgroup\$/dev/ttyACMx
(also withlsusb
) before trying to upload a sketch, I didn't try to burn the bootloader because I don’t have any ICSP programer, (I'm waiting for it to arrive) (actually it isn't Spanish it's Catalan very similar) \$\endgroup\$
