I'm not electric engineer, so maybe it is obvious, but I would like to know how do I test (in-circuit) aluminum polymer capacitor for failure? Electrolytic capacitor usually fail with easily visible damage to the aluminum case but polymer one (as I understand) look intact even in case of catastrophic failure.
Technicians often use an ESR (Equivalent Series Resistance) meter, which works in-circuit and will find open parts.
You can usually test in-circuit for shorts with an ohmmeter.
Testing is done with the power off and after discharging the capacitor in both cases, of course.
One crude test you can do if the cap is not shorted (to check for "open" or high ESR) is to parallel it (tack it on with a soldering iron) with a known-good capacitor and see if the circuit starts working. Only do this if you understand enough about the circuit to be sure it won't hurt anything.
| improve this answer | |
  • \$\begingroup\$ ohmmeter sounds good, is that mean that failed cap should be shorted and if it is not does it necessary means it is ok? \$\endgroup\$ – kreuzerkrieg Feb 18 '14 at 21:10
  • \$\begingroup\$ No, it could also be open (or have high ESR). Both tests are necessary. \$\endgroup\$ – Spehro Pefhany Feb 18 '14 at 21:12
  • \$\begingroup\$ oh, I see, thanks! And another question, since I cannot identify the cap manufacturer I don't have tech specs. how do I figure ESR numbers? \$\endgroup\$ – kreuzerkrieg Feb 18 '14 at 21:23
  • \$\begingroup\$ How do you know it's aluminum polymer? You can compare similar sizes and values of parts using a parametric search on (for example) digikey.com to get a rough idea. \$\endgroup\$ – Spehro Pefhany Feb 18 '14 at 21:24
  • \$\begingroup\$ just saw your edit with parallel capacitor, I can easily ruin the pcb :) but in any case, should I consider something but polarity? \$\endgroup\$ – kreuzerkrieg Feb 18 '14 at 21:30
