As a disclaimer, I have a little electronics knowledge, but I'm no expert. I've been given an old 1940's Hunter fan and I'm working on fixing it up. I took the base apart and wiring is pretty bad - cracked and bare in places... I'm going to replace it, but I'd like to understand what is going on -- how the variable speed works.
I've drawn a crappy diagram based on the wiring I see -- can anyone explain it?
wiring diagram
  • \$\begingroup\$ There is an error on your switch diagram? Usually black=hot, white=neutral, green=ground and red=hot (dimmed). What are the 3 functions? OFF-LO-HI or LO-HI-REVERSE? \$\endgroup\$ – rjobidon Feb 19 '14 at 4:45
  • \$\begingroup\$ @rjobidon a small point: just to clarify "usually black=hot" etc ... means "usually in America". We wouldn't want readers elsewhere in the world assuming this referred to their own wiring... \$\endgroup\$ – Brian Drummond Feb 19 '14 at 10:49
  • \$\begingroup\$ @rjobidon There might be an error - the switch speed functions are: high (green), medium (yellow & green to motor) and low (blue), and off (not shown) \$\endgroup\$ – jwill212 Feb 19 '14 at 12:35
