While creating a via, a drill shape somehow ended up on my dimension layer. Even though I've deleted the via the drill hole remains and produces an error. How can I edit the dimension layer and delete the drill hole?
Screenshot attached. Only the dimension layer (layer 20) is shown.
Eagle screenshot
  • \$\begingroup\$ Try to show all layers and then select top/bottom layer and place drill shape. \$\endgroup\$ – KernelPanic Feb 20 '14 at 8:07
It turns out this was an artifact left by the design rule check. Clearing the errors cleared the drill shape.
  • \$\begingroup\$ You can also use View | Redraw to refresh the current view. That often gets rid of any artifacts. \$\endgroup\$ – Chris Laplante Feb 27 '14 at 18:33
  • \$\begingroup\$ I'm glad you came back to address your own question. I was wondering how to recreate the problem so I could try and provide an answer. \$\endgroup\$ – JYelton Feb 27 '14 at 18:38
